MAG-LOOP
SP3SWJ Offline
Jarek
Liczba postów: 656
Post: #31
RE: MAG-LOOP
:-) Puzonowy tez dobra nazwa :-) podoba mi się :-)
http://www.on4ceq.net/ant_en.htm
a tu fajny "zafiksowany" capacitor na feldze rowerowej
http://www.qsl.net/hb9mtn/hb9mtn_rim-magnet.html
ale "motylki" są chyba najpopularniejsze ...
i jeszcze ten link ... na dole jest kilka kalkulatorów..
http://www.fucimin.altervista.org/en/loop.html
(Ten post był ostatnio modyfikowany: 24-02-2013 21:37 przez SP3SWJ.)
24-02-2013 21:35
MAG-LOOP - SP3SWJ - 15-12-2010, 18:19
RE: MAG-LOOP - SP2JQR - 15-12-2010, 20:07
RE: MAG-LOOP - SP8RHP - 15-12-2010, 23:23
RE: MAG-LOOP - SP3SWJ - 15-12-2010, 23:41
RE: MAG-LOOP - SP2JQR - 16-12-2010, 11:43
RE: MAG-LOOP - SP3SWJ - 16-12-2010, 21:47
RE: MAG-LOOP - 3Z6AEF - 16-12-2010, 22:26
RE: MAG-LOOP - SP3SWJ - 16-12-2010, 22:46
RE: MAG-LOOP - SP8RHP - 17-12-2010, 2:11
RE: MAG-LOOP - SP2JQR - 17-12-2010, 9:31
RE: MAG-LOOP - SQ4AVS - 17-12-2010, 10:22
RE: MAG-LOOP - SP8RHP - 18-12-2010, 2:48
RE: MAG-LOOP - SQ4AVS - 18-12-2010, 8:49
RE: MAG-LOOP - SQ6ADE - 18-12-2010, 10:58
RE: MAG-LOOP - SP2QCA - 19-12-2010, 6:18
RE: MAG-LOOP - SQ6ADE - 19-12-2010, 8:28
RE: MAG-LOOP - SQ9MTX - 23-01-2011, 18:24
RE: MAG-LOOP - SP3SWJ - 23-01-2011, 19:49
RE: MAG-LOOP - SQ9MTX - 06-02-2011, 20:52
RE: MAG-LOOP - SP6FRE - 10-02-2013, 22:08
RE: MAG-LOOP - SP3VZX - 11-02-2013, 16:10
RE: MAG-LOOP - SP6FRE - 11-02-2013, 22:44
RE: MAG-LOOP - SP6FRE - 20-02-2013, 21:51
RE: MAG-LOOP - SP3SWJ - 21-02-2013, 3:05
RE: MAG-LOOP - SP6FRE - 21-02-2013, 10:51
RE: MAG-LOOP - AdamC - 24-02-2013, 11:54
RE: MAG-LOOP - SP4EIB - 22-02-2013, 18:54
RE: MAG-LOOP - SP6FRE - 23-02-2013, 0:28
RE: MAG-LOOP - SP3SWJ - 23-02-2013, 23:28
RE: MAG-LOOP - SP6FRE - 24-02-2013, 19:30
RE: MAG-LOOP - SP3SWJ - 24-02-2013 21:35
RE: MAG-LOOP - SP6FRE - 25-02-2013, 13:19
RE: MAG-LOOP - SP3SWJ - 25-02-2013, 13:38
RE: MAG-LOOP - SP6FRE - 06-03-2013, 22:00
RE: MAG-LOOP - SP3SWJ - 06-03-2013, 23:25
RE: MAG-LOOP - SP6FRE - 07-03-2013, 8:48
RE: MAG-LOOP - SP3SWJ - 07-03-2013, 12:15
RE: MAG-LOOP - SP6FRE - 07-03-2013, 21:34
RE: MAG-LOOP - SP6FRE - 12-03-2013, 22:31
RE: MAG-LOOP - SP3SWJ - 12-03-2013, 22:37
RE: MAG-LOOP - SP6FRE - 13-03-2013, 8:49
RE: MAG-LOOP - SP6FRE - 21-03-2013, 9:14
RE: MAG-LOOP - SQ8MHI - 23-03-2013, 8:30
RE: MAG-LOOP - SP6FRE - 24-03-2013, 23:08
RE: MAG-LOOP - SP6FRE - 30-03-2013, 22:35
RE: MAG-LOOP - SP6FRE - 05-05-2013, 21:02
RE: MAG-LOOP - SQ9MLZ - 27-08-2013, 22:39
RE: MAG-LOOP - SQ8NYK - 17-08-2014, 10:46
RE: MAG-LOOP - SP3SWJ - 17-08-2014, 22:38
RE: MAG-LOOP - 3Z9N - 25-11-2014, 12:59
RE: MAG-LOOP - 3Z9N - 28-11-2014, 12:27
RE: MAG-LOOP - SP4NSJ - 30-04-2020, 16:45
RE: MAG-LOOP - SQ6COK - 24-06-2016, 12:56
RE: MAG-LOOP - SP2BPD - 24-06-2016, 17:22
RE: MAG-LOOP - SP4NSJ - 02-02-2018, 1:48
RE: MAG-LOOP - SP4NSJ - 21-02-2018, 1:28
RE: MAG-LOOP - SP3UQW - 03-03-2018, 9:18
RE: MAG-LOOP - SQ9JXT - 05-03-2018, 11:20
RE: MAG-LOOP - SP4NSJ - 16-04-2018, 17:10
RE: MAG-LOOP - SP1NV - 02-04-2019, 13:24
RE: MAG-LOOP - SQ8NZD - 14-07-2019, 16:43
RE: MAG-LOOP - SQ8MVY - 15-07-2019, 0:10
RE: MAG-LOOP - SQ8NZD - 21-07-2019, 6:08
RE: MAG-LOOP - AdamC - 21-07-2019, 9:56
RE: MAG-LOOP - SP9HZX - 08-06-2020, 12:57
RE: MAG-LOOP - SN5WD - 26-03-2021, 15:19
RE: MAG-LOOP - SN5WD - 28-04-2021, 9:20
RE: MAG-LOOP - SP9HZX - 07-08-2021, 7:36
RE: MAG-LOOP - SP9CNN - 03-01-2025, 18:33
