Synteza 4Z5KY na Si570
SQ7GVU Offline
Marcin
Liczba postów: 158
Post: #55
RE: Synteza 4Z5KY na Si570
Potwierdzam, ta wersja działa powyżej częstotliwości odbieranej i nie ma problemu z restartem. Dziękuję!
05-11-2012 4:25
Synteza 4Z5KY na Si570 - SP4HKQ - 14-04-2012, 18:15
RE: Synteza 4Z5KY na Si570 - SQ8Z - 15-04-2012, 17:06
RE: Synteza 4Z5KY na Si570 - SP1UJB - 16-04-2012, 10:49
RE: Synteza 4Z5KY na Si570 - SP5BMP - 16-04-2012, 11:11
RE: Synteza 4Z5KY na Si570 - TG50 - 16-04-2012, 11:15
RE: Synteza 4Z5KY na Si570 - SP4HKQ - 16-04-2012, 11:59
RE: Synteza 4Z5KY na Si570 - SQ8Z - 16-04-2012, 12:13
RE: Synteza 4Z5KY na Si570 - SP1UJB - 16-04-2012, 12:20
RE: Synteza 4Z5KY na Si570 - SP9HVW - 16-04-2012, 16:13
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 16-04-2012, 18:44
RE: Synteza 4Z5KY na Si570 - SP5BMP - 16-04-2012, 19:17
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 16-04-2012, 19:37
RE: Synteza 4Z5KY na Si570 - SP9FKP - 16-04-2012, 21:48
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 17-04-2012, 6:03
RE: Synteza 4Z5KY na Si570 - SP1UJB - 10-06-2012, 12:01
RE: Synteza 4Z5KY na Si570 - SP3RAF - 22-06-2012, 9:28
RE: Synteza 4Z5KY na Si570 - SP1UJB - 23-06-2012, 18:02
RE: Synteza 4Z5KY na Si570 - SP5BMP - 23-06-2012, 19:11
RE: Synteza 4Z5KY na Si570 - SP4HKQ - 23-06-2012, 21:02
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 23-06-2012, 21:09
RE: Synteza 4Z5KY na Si570 - SP5BMP - 23-06-2012, 21:48
RE: Synteza 4Z5KY na Si570 - SP4HKQ - 23-06-2012, 21:50
RE: Synteza 4Z5KY na Si570 - SP3RAF - 24-06-2012, 0:29
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 24-06-2012, 9:03
RE: Synteza 4Z5KY na Si570 - SP1UJB - 24-06-2012, 10:47
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 24-06-2012, 11:22
RE: Synteza 4Z5KY na Si570 - SP1UJB - 24-06-2012, 11:54
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 24-06-2012, 12:01
RE: Synteza 4Z5KY na Si570 - SP3RAF - 24-06-2012, 12:22
RE: Synteza 4Z5KY na Si570 - SP1UJB - 24-06-2012, 12:27
RE: Synteza 4Z5KY na Si570 - SP5BMP - 24-06-2012, 12:36
RE: Synteza 4Z5KY na Si570 - SP6FRE - 24-06-2012, 13:25
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 24-06-2012, 14:04
RE: Synteza 4Z5KY na Si570 - SP6FRE - 24-06-2012, 20:18
RE: Synteza 4Z5KY na Si570 - SQ4AVS - 24-06-2012, 20:29
RE: Synteza 4Z5KY na Si570 - SP3RAF - 24-06-2012, 22:54
RE: Synteza 4Z5KY na Si570 - SQ1GYQ - 24-06-2012, 23:15
RE: Synteza 4Z5KY na Si570 - SP3RAF - 25-06-2012, 9:14
RE: Synteza 4Z5KY na Si570 - SP3RAF - 27-06-2012, 16:27
RE: Synteza 4Z5KY na Si570 - SQ1GYQ - 27-06-2012, 18:26
RE: Synteza 4Z5KY na Si570 - SP5BMP - 27-06-2012, 20:25
RE: Synteza 4Z5KY na Si570 - SP3RAF - 27-06-2012, 23:53
RE: Synteza 4Z5KY na Si570 - SQ7GVU - 23-07-2012, 20:06
RE: Synteza 4Z5KY na Si570 - SP5BMP - 23-07-2012, 21:20
RE: Synteza 4Z5KY na Si570 - SQ7GVU - 23-07-2012, 21:55
RE: Synteza 4Z5KY na Si570 - SP5BMP - 24-07-2012, 7:53
RE: Synteza 4Z5KY na Si570 - SP3RAF - 28-07-2012, 1:21
RE: Synteza 4Z5KY na Si570 - SP3RAF - 31-07-2012, 17:55
RE: Synteza 4Z5KY na Si570 - SP3IQ - 23-08-2012, 18:17
RE: Synteza 4Z5KY na Si570 - SP3IQ - 24-08-2012, 11:25
RE: Synteza 4Z5KY na Si570 - SP5BMP - 24-08-2012, 13:32
RE: Synteza 4Z5KY na Si570 - SP3IQ - 04-10-2012, 23:49
RE: Synteza 4Z5KY na Si570 - SQ7GVU - 30-10-2012, 20:14
RE: Synteza 4Z5KY na Si570 - SP2JH - 03-11-2012, 8:10
RE: Synteza 4Z5KY na Si570 - SQ7GVU - 05-11-2012 4:25
RE: Synteza 4Z5KY na Si570 - SP6LTP - 21-11-2012, 16:15
RE: Synteza 4Z5KY na Si570 - SP2JQR - 08-03-2015, 16:26
RE: Synteza 4Z5KY na Si570 - SP5MET - 09-03-2015, 0:22
RE: Synteza 4Z5KY na Si570 - SP5BMP - 09-03-2015, 7:43
RE: Synteza 4Z5KY na Si570 - SP1UJB - 09-03-2015, 12:44
RE: Synteza 4Z5KY na Si570 - SP5MET - 09-03-2015, 13:19
RE: Synteza 4Z5KY na Si570 - SP5MET - 30-03-2015, 12:32
RE: Synteza 4Z5KY na Si570 - SQ7GVU - 30-03-2015, 20:01
RE: Synteza 4Z5KY na Si570 - SP5MET - 12-04-2015, 16:43
RE: Synteza 4Z5KY na Si570 - SP2JQR - 12-04-2015, 16:54
RE: Synteza 4Z5KY na Si570 - SP5MET - 12-04-2015, 17:36
RE: Synteza 4Z5KY na Si570 - SP5MET - 13-04-2015, 8:50
RE: Synteza 4Z5KY na Si570 - SQ6KBT - 18-10-2017, 14:55
RE: Synteza 4Z5KY na Si570 - SQ8MVY - 18-10-2017, 15:42
RE: Synteza 4Z5KY na Si570 - SQ6KBT - 17-11-2017, 10:04
Loading...
