  • 2 Głosów - 2.5 Średnio
TRX z AD831
UA1ARN Offline
Genadi
Liczba postów: 16
Post: #18
RE: TRX z AD831
sounds good... but: look TPC 9 on page 5 in .pdf: I'm use same output schematics - with output transformer 4:1.
These parameters (IP3) in AD document referred to output = IP3o. Gain of this chip near to 20 dB with properly matched input...
About LO level: i'm use -3..0 dBm source with 1:8 transformer at LO input. I'ts enough for AD831?
ps: in russian forums i'm place tagline "Я там глубину сам промерял!". I mean: "Byłem tam zmierzył głębokość!"
(Ten post był ostatnio modyfikowany: 17-05-2012 19:20 przez UA1ARN.)
17-05-2012 19:20
TRX z AD831 - SQ5MGA - 13-05-2012, 18:41
RE: TRX z AD831 - SP7ROH - 13-05-2012, 18:56
RE: TRX z AD831 - SQ5MGA - 13-05-2012, 19:18
RE: TRX z AD831 - SQ4AVS - 13-05-2012, 19:41
RE: TRX z AD831 - UA1ARN - 15-05-2012, 22:06
RE: TRX z AD831 - SP4HKQ - 13-05-2012, 19:44
RE: TRX z AD831 - SQ4AVS - 13-05-2012, 19:59
RE: TRX z AD831 - SP4HKQ - 13-05-2012, 21:34
RE: TRX z AD831 - SQ4AVS - 13-05-2012, 21:57
RE: TRX z AD831 - UA1ARN - 14-05-2012, 17:00
RE: TRX z AD831 - SP5BMP - 14-05-2012, 17:53
RE: TRX z AD831 - SQ4AVS - 14-05-2012, 18:32
RE: TRX z AD831 - UA1ARN - 14-05-2012, 22:36
RE: TRX z AD831 - SQ5MGA - 14-05-2012, 23:19
RE: TRX z AD831 - UA1ARN - 15-05-2012, 10:56
RE: TRX z AD831 - SQ5MGA - 15-05-2012, 22:00
RE: TRX z AD831 - SQ4AVS - 17-05-2012, 18:56
RE: TRX z AD831 - UA1ARN - 17-05-2012 19:20
RE: TRX z AD831 - SQ4AVS - 17-05-2012, 20:15
RE: TRX z AD831 - SP4EJT - 13-01-2013, 0:38
RE: TRX z AD831 - UA1ARN - 17-05-2012, 20:18
RE: TRX z AD831 - SQ5MGA - 21-05-2012, 10:57
RE: TRX z AD831 - SQ4AVS - 13-01-2013, 13:23
RE: TRX z AD831 - SP2FP - 09-12-2013, 22:54
RE: TRX z AD831 - SQ4AVS - 10-12-2013, 7:18
RE: TRX z AD831 - SP2FP - 20-12-2013, 12:39
RE: TRX z AD831 - SQ7GVU - 20-12-2013, 13:24
RE: TRX z AD831 - SP2FP - 20-12-2013, 14:11
RE: TRX z AD831 - SP2FP - 24-12-2013, 14:41
RE: TRX z AD831 - SP2FP - 07-01-2017, 22:12
