  • 3 Głosów - 3.33 Średnio
SQ2EER Offline
Jacek sk
Liczba postów: 182
RE: Programowanie w języku C w środowisku AVR Studio4
Witam - po doinstalowaniu Toolchain jest taki efekt
rm -rf lcd.o lcd.elf dep/* lcd.hex lcd.eep lcd.lss lcd.map
c:\Program Files\Atmel\AVR Tools\AVR Toolchain\bin\rm.exe: nie można wykonać lstat na `dep/*': Invalid argument
make: [clean] Błąd 1 (zignorowany)
Build succeeded with 0 Warnings...
avr-gcc -mmcu=atmega32 -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT lcd.o -MF dep/lcd.o.d -c ../lcd.c
In file included from ../lcd.c:6:0:
c:\program files\atmel\avr tools\avr toolchain\bin\../lib/gcc/avr/4.5.1/../../../../avr/include/util/delay.h:89:3: warning: #warning "F_CPU not defined for <util/delay.h>"
avr-gcc -mmcu=atmega32 -Wl,-Map=lcd.map lcd.o -o lcd.elf
avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature lcd.elf lcd.hex
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex lcd.elf lcd.eep || exit 0
avr-objdump -h -S lcd.elf > lcd.lss
AVR Memory Usage
Device: atmega32
Program: 324 bytes (1.0% Full)
(.text + .data + .bootloader)
Data: 0 bytes (0.0% Full)
(.data + .bss + .noinit)
Build succeeded with 1 Warnings...
Smile pozdrawiam 73 Jacek.
13-01-2012 21:29
RE: Programowanie w języku C w środowisku AVR Studio4 - SQ2EER - 13-01-2012 21:29
