Tranciever Тюльпан-DSP - Wersja do druku +- HomeMade (http://sp-hm.pl) +-- Dział: Urządzenia nadawczo odbiorcze KF (/forum-62.html) +--- Dział: Transceivery HomeMade (/forum-64.html) +--- Wątek: Tranciever Тюльпан-DSP (/thread-2339.html) Strony: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 |
RE: Tranciever Тюльпан-DSP - UA6VAE - 12-03-2016 5:35 (12-03-2016 2:24)SP3OSJ napisał(a): You have a set: Menu/global ...../Band to 74HC595N -> ENABLE? Yes. It was first i had made It turned out to be my own fail, i used jumpers instead of coils in BPF to speed up diagnostic and have not looking at scheme... and made REAL short. Now it's fine, but lot of shame What to do with this spike? It persist in receiving mode and transmitting as well, together with modulated signal always hearable tone. Like DDS frequency is leaking to transmit tract. Is it resolve with shielding (ecraning) PO* IC's? Also, i'm not mistake with thoughts that BPF mapping in control circuit not match with software settings by default? Because when 40m diapason selected, not right relays are turned on. test test test RE: Tranciever Тюльпан-DSP - SP3OSJ - 14-03-2016 12:25 ..... RE: Tranciever Тюльпан-DSP - UA6VAE - 14-03-2016 13:28 Thank you, i have figured this out. But what about those spike? Shielding problem? Also, how much thick is metal plate are you used for shielding between PCB's and onboard shielding? RE: Tranciever Тюльпан-DSP - SP2GNB - 14-03-2016 14:02 Witam, Mój problem z ekranem: Do dziś wszystko OK. Delikatnie, bez jakichkolwiek naprężeń zamontowałem do obudowy i dostałem efekt jak w załączniku. W pierwszej chwili sądziłem, że z niewiadomych przyczyn wzrósł prąd podświetlenia, ale zasilacz tego nie wykazał. Wygląda na problem z kontrastem, jasność mam fabryczną 110. Ekran połączony ze sterownikiem złączem szpilkowym, bez taśmy. Klawisze zrobiły się jasnoszare, białe napisy prawie nieczytelne... Ktoś z Was takie coś trenował? Czy możecie przypomnieć mi opcje przy zamawianiu ekranu? (Nie pamiętam, sorry) [attachment=10927] RE: Tranciever Тюльпан-DSP - SQ8MVY - 14-03-2016 14:35 Witam, Sprawdź, czy LCD reaguje na zmianę jasności podświetlania z poziomu ustawień sterownika. Pozdrawiam RE: Tranciever Тюльпан-DSP - SP2GNB - 14-03-2016 14:51 Reaguje...Bez problemu, w ogóle sterownik działa... RE: Tranciever Тюльпан-DSP - SP3OSJ - 14-03-2016 19:24 ..... RE: Tranciever Тюльпан-DSP - SP2GNB - 14-03-2016 20:17 Jeszcze dziś spróbuję. Przypomnijcie mi jak zamawia się ekran... Tak na wszelki wypadek... RE: Tranciever Тюльпан-DSP - UA6VAE - 14-03-2016 20:31 (14-03-2016 20:17)SP2GNB napisał(a): Jeszcze dziś spróbuję. Przypomnijcie mi jak zamawia się ekran... Tak na wszelki wypadek... http://www.buydisplay.com/default/5-inch-tft-lcd-module-800x480-display-controller-i2c-serial-spi 8080 parallel and 3v3 dc supply, touchscreen as desired. RE: Tranciever Тюльпан-DSP - SQ8MVY - 14-03-2016 21:22 Witam, Podejrzewam, że przez przypadek coś się Ci zwarło przy włączaniu. Kontrast nie jest ustawiany programowo, tylko sprzętowo. Odpowiada za to pin VCOM (nr 46) na tasiemce panela TFT( ta co łączy wyświetlacz TFT z RA8875). Z dokumentacji wynika, że powinno być tam napięcie typowo 4.4V ( min. 3.4V, max. 5.4V). Ustawiane jest przez dzielnik rezystancyjny. Napięcie na ten dzielnik idzie z przetwornicy zasilającej tor analogowy panela TFT (pin 43) -typowo 10.4V. Do sprawdzenia jeszcze napięcia VGH (pin 41) - typowo 16V, oraz VGL (pin 42) - typowo -7V (minus 7 volt). Wszystkie napięcia podałem z noty katalogowej panela TFT 8 cali, użytego w tym LCD. Przy zamawianiu ważny jest interfejs - 8080, panel dotykowy rezystancyjny. Pozdrawiam |
