Tranciever Тюльпан-DSP - Wersja do druku +- HomeMade (http://sp-hm.pl) +-- Dział: Urządzenia nadawczo odbiorcze KF (/forum-62.html) +--- Dział: Transceivery HomeMade (/forum-64.html) +--- Wątek: Tranciever Тюльпан-DSP (/thread-2339.html) Strony: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 |
RE: Tranciever Тюльпан-DSP - HMAMATOR - 08-03-2016 19:04 Taki jak w oryginalej dokumentacji na stronie http://www.cqham.ru/. RE: Tranciever Тюльпан-DSP - UA6VAE - 09-03-2016 0:09 Faced with a strange problem. As I connect the DDS output to DDS(4) through NB3N3020 what I should use as DDS mux and Frequency factor? I used 4 (DDS mux) and 1 (Freq factor) at this moment and heard very weak tone signal when test with Tone button and my scanner. When i feed TRX with line in source i saw on FFT window actual signal pattern but heard nothing with scanner... RE: Tranciever Тюльпан-DSP - SP3OSJ - 09-03-2016 10:05 ..... RE: Tranciever Тюльпан-DSP - UA6VAE - 09-03-2016 10:07 (09-03-2016 10:03)SP3OSJ napisał(a): DDS -> X1 (Menu)Hi! NB3N3020 soldered to X4 with 0 Ohm resistance. You mean: DDSmux -1 Freq factor -4 ? Anyway, not working. From what point i need to start diagnostic? RE: Tranciever Тюльпан-DSP - SP3OSJ - 09-03-2016 21:17 ..... RE: Tranciever Тюльпан-DSP - SP9KN - 10-03-2016 9:34 A ja z chęcią kupię kompletnego DDS-a lub samą płyteczkę do DDS TRX Tulip. RE: Tranciever Тюльпан-DSP - UA6VAE - 11-03-2016 23:17 I am really frustrated about this SWR meter. Why the ANT literally shorted to ground? RE: Tranciever Тюльпан-DSP - SP3OSJ - 12-03-2016 0:46 ..... RE: Tranciever Тюльпан-DSP - UA6VAE - 12-03-2016 1:48 (12-03-2016 0:46)SP3OSJ napisał(a): This is not a short circuit there is a transformer (inductance "L")! Yes, it's inductance, but it have zero resistance and short all circuit (LPF, BPF) and TRX output/input directly to ground. Simply, if i'm apply test signal of 7Mhz from generator to ANT input, i see very weak signal on display, but if i'm disconnecting PA board and connect generator directly to TX input of TRX board, signal is very strong. Maybe i have miss something... Okay, one more thing i thought i shall mistake. Now i have shorted all inductance within LPF and BPF for 40m diapason (as i test on 40m), instead installing coils, it's just faster. Is it critical? May be this is reason of signal loss? RE: Tranciever Тюльпан-DSP - SP3OSJ - 12-03-2016 2:24 ..... |
