RE: Tranciever Тюльпан-DSP - UA6VAE - 28-12-2015 1:08
Aaa, you mean this one İmage ?
And so, all capacitors on TRX3(PCB2) board can be 10v... right?
RE: Tranciever Тюльпан-DSP - SP3OSJ - 28-12-2015 1:14
RE: Tranciever Тюльпан-DSP - UA6VAE - 28-12-2015 1:42
Now i see, thank you, Artur!
Shy Bardzo doceniane!
RE: Tranciever Тюльпан-DSP - PD0RBO - 28-12-2015 22:13
The specification for the BLM? Is 31Ohm@100Mhz/1,5A Ok? I got TDK 321611 beads
RE: Tranciever Тюльпан-DSP - UA6VAE - 28-12-2015 22:19
The encoders. ALPS EC12E2420404, how it described on UI board.
Here, it on the attached photos, just get it from post office and it does not look like it should.
Where to find proper encoders?
[attachment=10641][attachment=10640]
(28-12-2015 22:13)PD0RBO napisał(a):  The specification for the BLM?
Should be OK.
[attachment=10642]
RE: Tranciever Тюльпан-DSP - PD0RBO - 28-12-2015 22:48
http://m.ebay.com/itm/New-10pcs-12mm-Rotary-Encoder-Push-Button-Switch-Keyswitch-Electronic-Components-/331262931119?nav=SEARCH
(28-12-2015 22:19)UA6VAE napisał(a):  Where to find proper encoders?
Still got some left from another project, still got to look into if these are usable. But on first glance should be the encoders that will do.
RE: Tranciever Тюльпан-DSP - UA6VAE - 28-12-2015 23:51
Wow, look nice, but it is not ALPS... newermind, thank you!
Remi, maybe you know link for variable 50Khom volume potentiometer? What I've found not correct sizing, like this.
It's 15x11mm, not 9x11.
I got a parcel with PCB and case this morning, I've not awaited it in this year, but it came! Yay!
Thanks to Artur, for such great gift for New Year holidays Smile
RE: Tranciever Тюльпан-DSP - PD0RBO - 29-12-2015 19:29
I did not look closely yet, in week 1 and 2 next year I have days off and have more spare time to look for parts.. Now just in a glance I found this:
http://m.ebay.com/itm/2-x-9mm-CTR-S3W-B50K-50K-Linear-Taper-Potentiometer-Rotary-Switch-15mm-Shaft-/251533747081?nav=SEARCH
100Pcs/lot SMT 6x6x11mm SMD 4Pins Tactile Tact Push Button Micro Switch Momentary 6*6*11mm
http://s.aliexpress.com/yUnq2uyA
RE: Tranciever Тюльпан-DSP - SP3OSJ - 29-12-2015 22:35
RE: Tranciever Тюльпан-DSP - K2KP - 31-12-2015 3:59
Mam kilka pytan do doswiadczonych w budowie tulipa a mianowicie:
1. Sterownik mam juz uruchomiony i wgrane ostatnie oprogramowanie (sys11082015). Wszystko dzial ok. Mam rowniez zlozona plytke DSP i wgrane oprogramowanie . Tutaj jednak zaczynaja sie schody. Czy jest mozliwosc sprawdzenia plytki DSP ze sterownikiem?Na wyswietlaczu (pandapter) nic nie widac . A poziom sygnalu -150dB. Czy jest to normalne ? Jak podaj sygnal wejscie filtra 23khz ( np. z jakiegos sdr albo dwa sygnaly powiedzmy 20khz z generatora) to czy na panadapterze bedzie je widac I bedzie je slychac w wyjsciu sluchawkowym? Dodam ze wzmacniacz wyjsciowy dziala poprawnie . Znaczy sie wszystko za kodekiem jest ok.
2.Jakim sygnalem moge sterowac wejscie DSP plytki( wejscie RX 23khz )?
3. Jak mozna sprawdzic czy DSP dziala ? I czy ma komunikacje z glownym sterownikiem?
Dodam ze DSP mam versji Z i ze to wersja na 4 plytkach.
Arek
