RE: Tranciever Тюльпан-DSP - PD0RBO - 24-11-2015 15:17
BOM PCB3 reviewed, supplemented and augmented
BOM PCB2 Initial setup but needs to be reviewed like the AD8676/NE5532 has to be recounted as the NPN/PNP transistors as I feel I messed up counting them.
RE: Tranciever Тюльпан-DSP - SP2GNB - 29-11-2015 22:09
Nieuchronnie zbliża się moment uruchomienia Tulipana... Sterownik działa, no może nie na ostatniej wersji programu, upgrade później. W tygodniu przyjdzie ostatni element - procek DDSa.
Skłamałbym, gdybym powiedział, że wiem jak to uruchomić bez dymienia Confused...
Jakieś podpowiedzi, słowa otuchy, wskazówki?
RE: Tranciever Тюльпан-DSP - PD0RBO - 06-12-2015 16:53
I've made an initial estimate of the first setup cost's of the SP3OSJ design based on the prices found on Mouser and included the Dutch 21% tax.
Included in the estimate are the PCB/Button/housing kit, LCD, TCXO, encoder, all the parts for the UI board and the aditional extra parts for the TRX and PA board to achieve extra discount per part.
I did not tweak the order list yet, nor did I compare prices with Farnell or other trustworthy suppliers.
If someone could review the list I made, I would be grateful. Recommendations would be helpful too
RE: Tranciever Тюльпан-DSP - SP3OSJ - 06-12-2015 19:59
RE: Tranciever Тюльпан-DSP - SP5TAA - 06-12-2015 23:42
Hi Remi,
I`m not ,,playing" now with Tulipan yet but I will start to assembly it soon, meantime I am lookig for parts for that radio...I have not any expirience with this radio but
I hope this link could be interesting for you:
http://www.buydisplay.com/default/5-inch-tft-lcd-module-800x480-display-controller-i2c-serial-spi
I crose my fingers to you.
Witek, SP5TAA
RE: Tranciever Тюльпан-DSP - PD0RBO - 07-12-2015 11:21
(06-12-2015 19:59)SP3OSJ napisał(a):  Remi, thanks for your work.
Tnx happy to, with bigger projects I always do to ceep the cost's in track D
(06-12-2015 23:42)SP5TAA napisał(a):  Hi Remi,
Witek, SP5TAA
Ik hope the list comes handy, keep in mind that I did not add the TRX and PA board yet. I will make seperate lists for these boards. Tnx for the link, sadly I already ordered my LCD for $45,- I'll check and review the link and add it to the list
RE: Tranciever Тюльпан-DSP - SP9KN - 10-12-2015 22:31
Czy ma któryś z kolegów na forum skończonego Tulipana ale w tej wersji 4 płytkowej?
Tej co w poście: 193 http://sp-hm.pl/thread-2339-post-25634.html#pid25634
Mógłbym prosić o zdjęcia polutowanych płytek, zwłaszcza tej z filtrami ? Może być na prv (guru@hot.pl)
Dziękuję i pozdrawiam.
Przemek
RE: Tranciever Тюльпан-DSP - SP6AUO - 12-12-2015 18:56
Wymieniłem układy 74HC4066 na 74LVC4066D.
Odniosę się do wrażeń wzrokowo słuchowych na 28MHz.
Jest OK.Jestem zdumiony.Na 28MHz sygnał po BPF jest o 0.2Vpp większy od sygnału z pasma 3,7MHz.
Wcześniej był 3 razy mniejszy.To dotyczy Tx.
Dla Rx też jestem zadowolony.Przed wymianą miałem 70% pola spektrum zaśmiecone.Teraz pole jest czyste.
Dziś były zawody mogłem wybierać między około 10 stacjami na 28MHz,na antenie inverted V z 80m,czyli 38m drutu.
Poziom szumu bez anteny S=3,z anteną (tym drutem) S=4.Stacje wychodziły od S=7 nawet do S=9+10.
Dużo wyżej ponad tło szumu. Warto było.
Myślę jeszcze o wymianie układu U8.
RE: Tranciever Тюльпан-DSP - SP3OSJ - 13-12-2015 16:25
RE: Tranciever Тюльпан-DSP - SP4SKP - 13-12-2015 17:49
Ostatnie zdanie zwala z nóg !!
