08-03-2016, 18:04
Taki jak w oryginalej dokumentacji na stronie http://www.cqham.ru/.
Ryszard 73
Tranciever Тюльпан-DSP
08-03-2016, 23:09
Faced with a strange problem.
As I connect the DDS output to DDS(4) through NB3N3020 what I should use as DDS mux and Frequency factor? I used 4 (DDS mux) and 1 (Freq factor) at this moment and heard very weak tone signal when test with Tone button and my scanner. When i feed TRX with line in source i saw on FFT window actual signal pattern but heard nothing with scanner...
10-03-2016, 8:34
A ja z chęcią kupię kompletnego DDS-a lub samą płyteczkę do DDS TRX Tulip.
11-03-2016, 22:17
I am really frustrated about this SWR meter.
Why the ANT literally shorted to ground? (11-03-2016, 23:46)SP3OSJ napisał(a): This is not a short circuit there is a transformer (inductance "L")! Yes, it's inductance, but it have zero resistance and short all circuit (LPF, BPF) and TRX output/input directly to ground. Simply, if i'm apply test signal of 7Mhz from generator to ANT input, i see very weak signal on display, but if i'm disconnecting PA board and connect generator directly to TX input of TRX board, signal is very strong. Maybe i have miss something... Okay, one more thing i thought i shall mistake. Now i have shorted all inductance within LPF and BPF for 40m diapason (as i test on 40m), instead installing coils, it's just faster. Is it critical? May be this is reason of signal loss? |
