FT-818 i TCXO-9
#6
Hej.
A dodatkowo to co dostałem od techników Yeasu.
(06-07-2021, 7:59)technik Yeasu napisał(a): ...
All FT-818s have the TCXO fitted as standard.
I have listed the specifications below for the FT-818 and the FT-817.
You will see that the FT-818 stability is +/- 0.5 ppm, which is the same as the older FT-817 with the TXO filled.
Pozdrawiam Grzegorz.
FT-818 i TCXO-9 - przez SQ6ILB - 05-07-2021, 16:36
