Transceiver wg. M0NKA
Nowy firmware 194.
.zip   mchf_firm_0_194_ka7oei_20141025.zip (Rozmiar: 79.52 KB / Pobrań: 980)
Dużo zmian, nalezy zapoznać się z ich listą.
.pdf   modification_log_ka7oei_ver_0_0_0_194.pdf (Rozmiar: 181.25 KB / Pobrań: 2,032)
Wersja 194 "wygląda" super a tutaj mamy kolejną wersję 195 Smile.
Changes include:
- Problem of CW mode being "broken" after exiting TUNE mode now fixed, I think.
- Added multiple center frequencies for 300Hz, 500Hz, 1.8 kHz and 2.3 kHz filters.
- Renamed "2.6 kHz" to "2.3 kHz" filter as that is actually it's bandwidth!
- Added options to disable all filters, except the 2.3 kHz filter, if desired.
- Renumbered all menu items and changed various colors in the menu.
- CW Sidetone and TX offset range is now 400-1000 Hz, adjustable in 10Hz steps.
.zip   mchf_firm_0_195_ka7oei_20141026.zip (Rozmiar: 82.21 KB / Pobrań: 983)
Wersja 196
A few other changes that might interest other people reading this:
- You can now disable the temperature sensor entirely: The TCXO On/OFF has a "STOP" selection, now, that will stop the polling of the sensor, whichcan be used stop the 1 second "TICK" sound for those who have not made the modification to do so.
- The CAT option has been moved to the "Adjustment" menu and is no longer on the main screen.
- The keyer mode setting has been removed from button G2 and is no longer displayed on the main screen, but is available, along with other CW options, in the menu.
.zip   mchf_firm_0_196_ka7oei_20141026.zip (Rozmiar: 82.35 KB / Pobrań: 907)
