Transceiver wg. M0NKA
Komunikatu nie mam (zmiany zrobione), a t2 i t3 nawinalem zgodnie z instrukcją - sprawdze to jeszcze. Właśnie te nieregularne zmiany kieruja mnie na bpf, a że je sprawdziłem i przelutowalem, to w kierunku u1 i u2. Sprawdzę jutro i napisze, dzis musze sie wyspac Smile
Arek
Moze kogos zainteresuje ale najnowsza wersja firmware pozwala pracowac na FreeDV. Mozna umowic sie na QSO na FreeDV na stronie http://qso.freedv.org/ logujac sie swoim znakiem
Mozna posluchac na FreeDV na 7177 khz VK5ARG w kazda niedziele o 10:00 ACST (0030 UTC) http://www.areg.org.au/archives/2136
Hi,
the mchF Software Team would like to announce the availability of FreeDV 1600 support
in the current daily builds.
For those who don't know FreeDV: It is a open source digital voice codec
and digital transmission modem. See https://en.wikipedia.org/wiki/Codec2 and http://freedv.org
With help of David Rowe, the main Codec2 developer (Thank you!) we were able to integrate the FreeDV
code into the mcHF.
This makes the mcHF the first (non-PC based) SDR which runs FreeDV internally.
This first release is a milestone but of course not the end of the journey.
It needs to be tested and there will be bugs, for sure.
How to get started:
- Download the most recent daily build from https://df8oe.github.io/mchf-github
- Switch to LSB or USB, dial into an appropriate frequency.
- Touch the "Digital" box in the lower left side. It will switch to "FreeDV" with orange background.
- Press PTT and you are on air with FreeDV!
[You will need a touch screen enabled mcHF for now or you have to change the
source and compile to automatically enable FreeDV when turned on (mchf_freedv.c, init function)]
Any report appreciated!
In case of issues, have a look at https://github.com/df8oe/mchf-github/issues and
possibly add one, if not already mentioned there.
73
Danilo, DB4PLE
SP5SMK: tak jak pisałeś, problemem są filtry LPF - niestety nie mam czym ich pomierzyć, własnie stad wynika na przykład niższa moc na 40m. Muszę zastanowić sie jak je sprawdzić lub poszukać kogoś kto mi w tym pomoże.
Co do mocy, to wymieniłem tranzystory na BFQ 17 i spokojnie w pasmach 80m-20m (poza 40m) mam 10 W. Wróciłem do polaryzacji biasu dla driverów z napięcia zasilania i okazuje się, że przy zasilaniu z PTT +5V i zmianie rezystorów na 2,2k drivery były wysterowane wyższym napięciem i dawały większą moc. Patrząc na to jak zachowuje się BFQ 17 zdecydowanie lepiej wrócić do tego modu.
Jeśli to filtr LPF to proponuję najpierw sprawdzić, czy jest przejście dla DC. Może w którejś cewce jest źle zeskrobana izolacja z drutu. A w drugiej kolejności wymienić kondensatory na nowe o sprawdzonej pojemności. Więcej problemów będzie z filtrem BPF bo tam można sprawdzić tylko lutowanie pojedyńczych cewek. Ja po zmontowaniu układu sprawdziłem iltry na analizatorze obwodów w QRL-u. Jeśli Kolega mieszka lub bywa w Warszawie, to możemy się umówić na pomiary.
Co do tranzystorów BFQ17, to mają one wyraźnie mniejsze wzmocnienie prądowe niż oryginalne. Z tego powodu obwód polaryzacji bazy musi mieć mniejsze rezystancje. Ja dałem dwa rezystory po 1k i mam około 2V na bazach. W oryginalnym układzie miałem prawie 2,5V. Na razie jeszcze nie sprawdzałem mocy, może jutro to zrobię pomiary. Być może trzeba będzie zwiększyć rezystor od strony masy ale to trzeba dopiero policzyć.
Wojciech
Odpowiedzialem na prv
Arek
SO5HMI
Witam wszystkich budowniczych SDR-a M0NKA
Składam ten projekt już prawie 2 lat. Z racji tego że zacząłem też składać SDR-a Tulip nie wypada aby zakończył nowy projekt przed zakończeniem starego.
Zatem prace ruszyły dalej do przodu. Uruchomiłem PCB UI wykonałem na niej zalecane modyfikacje łącznie z okablowaniem pod wyświetlacz dotykowy.
I tu pojawił się problem. Wyświetlacz jaki posiadam to HY28B przełączony na zworkach w tryb SPI. Wgrane oprogramowanie DF8OE 1.2.0.
Wyświetlacz uruchamia się poprawnie program staruje a ekran dotykowy reaguje na dotyk, ale nie reaguje zmianą funkcji.
Uruchomiłem płytkę w trybie testowym, który wykazuje że touchpanel reaguje. Nieważne jaki obszar ekranu dotknę zawsze zgłasza pozycję dotyku x=60 y=0.
Nie wiem gdzie leży problem i jak sobie z nim poradzić.
Zamieszczam zdjęcie wyświetlacza oraz modyfikacji wykonanej na PCB UI.
Ja nie potrafię dopatrzyć się tutaj błędu. Prosiłbym o jakieś wskazówki, sugestie.
A ja mam inny problem....
Mam biały ekran na wyświetlaczu...Wyświetlacz sprawdzony przed wysyłką - działał...
Samo radio działa ok, słyszę jak przekaźniki klepią, ale obrazu brak./
Przemek,za mało danych,żeby stwierdzić co dolega.Jaki LCD ?
Układ M0,M1,M2, gdzie 0 a gdzie 1 ?
Jaki FW ?
Jaka PCB ,niebieska czy czerwona.Jak niebieska to jaka ver. ?
    Przy jednym egzemplarzu M0NKA miałem biały ekran. Firmware 0.219.26.5 (KA7OEI) STM32F407 VGT6 Czasami zaskakiwał i działał przeważnie na zimno. Po wymianie na taki sam jest OK
Na fotce jest ten co świecił na biało ,nawet został polutowany ale nie sprawdzony czy dolegliwości ustąpiły.
Płyta niebieska 04
Ta kulka cyny pomiędzy 15 i 16 nóżką U1 wygląda podejrzanie...
