Tranciever Тюльпан-DSP
BOM PCB3 reviewed, supplemented and augmented
BOM PCB2 Initial setup but needs to be reviewed like the AD8676/NE5532 has to be recounted as the NPN/PNP transistors as I feel I messed up counting them.
.pdf   BOM-PCB3v1.04.pdf (Rozmiar: 141.33 KB / Pobrań: 1,457)
.pdf   BOM-PCB2v1.01.pdf (Rozmiar: 151.84 KB / Pobrań: 1,256)
Wybacz mój język , pisać i czytać mi z nim za pomocą Google Translate
Nieuchronnie zbliża się moment uruchomienia Tulipana... Sterownik działa, no może nie na ostatniej wersji programu, upgrade później. W tygodniu przyjdzie ostatni element - procek DDSa.
Skłamałbym, gdybym powiedział, że wiem jak to uruchomić bez dymienia Confused...
Jakieś podpowiedzi, słowa otuchy, wskazówki?
73 Staszek SP2GNB
I've made an initial estimate of the first setup cost's of the SP3OSJ design based on the prices found on Mouser and included the Dutch 21% tax.
Included in the estimate are the PCB/Button/housing kit, LCD, TCXO, encoder, all the parts for the UI board and the aditional extra parts for the TRX and PA board to achieve extra discount per part.
I did not tweak the order list yet, nor did I compare prices with Farnell or other trustworthy suppliers.
If someone could review the list I made, I would be grateful. Recommendations would be helpful too
.pdf   BOM 1st order-tranche v1.01.pdf (Rozmiar: 268.24 KB / Pobrań: 1,322)
Hi Remi,
I`m not ,,playing" now with Tulipan yet but I will start to assembly it soon, meantime I am lookig for parts for that radio...I have not any expirience with this radio but
I hope this link could be interesting for you:
http://www.buydisplay.com/default/5-inch...serial-spi
I crose my fingers to you.
Witek, SP5TAA
(06-12-2015, 18:59)SP3OSJ napisał(a): Remi, thanks for your work.
Tnx happy to, with bigger projects I always do to ceep the cost's in track D
(06-12-2015, 22:42)SP5TAA napisał(a): Hi Remi,
Witek, SP5TAA
Ik hope the list comes handy, keep in mind that I did not add the TRX and PA board yet. I will make seperate lists for these boards. Tnx for the link, sadly I already ordered my LCD for $45,- I'll check and review the link and add it to the list
Czy ma któryś z kolegów na forum skończonego Tulipana ale w tej wersji 4 płytkowej?
Tej co w poście: 193 http://sp-hm.pl/thread-2339-post-25634.html#pid25634
Mógłbym prosić o zdjęcia polutowanych płytek, zwłaszcza tej z filtrami ? Może być na prv (guru@hot.pl)
Dziękuję i pozdrawiam.
Przemek
Wymieniłem układy 74HC4066 na 74LVC4066D.
Odniosę się do wrażeń wzrokowo słuchowych na 28MHz.
Jest OK.Jestem zdumiony.Na 28MHz sygnał po BPF jest o 0.2Vpp większy od sygnału z pasma 3,7MHz.
Wcześniej był 3 razy mniejszy.To dotyczy Tx.
Dla Rx też jestem zadowolony.Przed wymianą miałem 70% pola spektrum zaśmiecone.Teraz pole jest czyste.
Dziś były zawody mogłem wybierać między około 10 stacjami na 28MHz,na antenie inverted V z 80m,czyli 38m drutu.
Poziom szumu bez anteny S=3,z anteną (tym drutem) S=4.Stacje wychodziły od S=7 nawet do S=9+10.
Dużo wyżej ponad tło szumu. Warto było.
Myślę jeszcze o wymianie układu U8.
Ostatnie zdanie zwala z nóg !!
