Tranciever Тюльпан-DSP - Wersja do druku +- Forum HomeMade (https://sp-hm.pl) +-- Dział: Urządzenia nadawczo odbiorcze KF (https://sp-hm.pl/forum-10.html) +--- Dział: Transceivery HomeMade (https://sp-hm.pl/forum-48.html) +--- Wątek: Tranciever Тюльпан-DSP (/thread-1558.html) Strony:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
RE: Tranciever Тюльпан-DSP - PD0RBO - 24-11-2015 BOM PCB3 reviewed, supplemented and augmented BOM PCB2 Initial setup but needs to be reviewed like the AD8676/NE5532 has to be recounted as the NPN/PNP transistors as I feel I messed up counting them. RE: Tranciever Тюльпан-DSP - SP2GNB - 29-11-2015 Nieuchronnie zbliża się moment uruchomienia Tulipana... Sterownik działa, no może nie na ostatniej wersji programu, upgrade później. W tygodniu przyjdzie ostatni element - procek DDSa. Skłamałbym, gdybym powiedział, że wiem jak to uruchomić bez dymienia ...Jakieś podpowiedzi, słowa otuchy, wskazówki? RE: Tranciever Тюльпан-DSP - PD0RBO - 06-12-2015 I've made an initial estimate of the first setup cost's of the SP3OSJ design based on the prices found on Mouser and included the Dutch 21% tax. Included in the estimate are the PCB/Button/housing kit, LCD, TCXO, encoder, all the parts for the UI board and the aditional extra parts for the TRX and PA board to achieve extra discount per part. I did not tweak the order list yet, nor did I compare prices with Farnell or other trustworthy suppliers. If someone could review the list I made, I would be grateful. Recommendations would be helpful too RE: Tranciever Тюльпан-DSP - SP3OSJ - 06-12-2015 ..... RE: Tranciever Тюльпан-DSP - SP5TAA - 06-12-2015 Hi Remi, I`m not ,,playing" now with Tulipan yet but I will start to assembly it soon, meantime I am lookig for parts for that radio...I have not any expirience with this radio but I hope this link could be interesting for you: http://www.buydisplay.com/default/5-inch-tft-lcd-module-800x480-display-controller-i2c-serial-spi I crose my fingers to you. Witek, SP5TAA RE: Tranciever Тюльпан-DSP - PD0RBO - 07-12-2015 (06-12-2015, 18:59)SP3OSJ napisał(a): Remi, thanks for your work. Tnx happy to, with bigger projects I always do to ceep the cost's in track D (06-12-2015, 22:42)SP5TAA napisał(a): Hi Remi, Ik hope the list comes handy, keep in mind that I did not add the TRX and PA board yet. I will make seperate lists for these boards. Tnx for the link, sadly I already ordered my LCD for $45,- I'll check and review the link and add it to the list RE: Tranciever Тюльпан-DSP - SP9KN - 10-12-2015 Czy ma któryś z kolegów na forum skończonego Tulipana ale w tej wersji 4 płytkowej? Tej co w poście: 193 http://sp-hm.pl/thread-2339-post-25634.html#pid25634 Mógłbym prosić o zdjęcia polutowanych płytek, zwłaszcza tej z filtrami ? Może być na prv (guru@hot.pl) Dziękuję i pozdrawiam. Przemek RE: Tranciever Тюльпан-DSP - SP6AUO - 12-12-2015 Wymieniłem układy 74HC4066 na 74LVC4066D. Odniosę się do wrażeń wzrokowo słuchowych na 28MHz. Jest OK.Jestem zdumiony.Na 28MHz sygnał po BPF jest o 0.2Vpp większy od sygnału z pasma 3,7MHz. Wcześniej był 3 razy mniejszy.To dotyczy Tx. Dla Rx też jestem zadowolony.Przed wymianą miałem 70% pola spektrum zaśmiecone.Teraz pole jest czyste. Dziś były zawody mogłem wybierać między około 10 stacjami na 28MHz,na antenie inverted V z 80m,czyli 38m drutu. Poziom szumu bez anteny S=3,z anteną (tym drutem) S=4.Stacje wychodziły od S=7 nawet do S=9+10. Dużo wyżej ponad tło szumu. Warto było. Myślę jeszcze o wymianie układu U8. RE: Tranciever Тюльпан-DSP - SP3OSJ - 13-12-2015 ..... RE: Tranciever Тюльпан-DSP - SP4SKP - 13-12-2015 Ostatnie zdanie zwala z nóg !! |
