  • 9 Głosów - 4.44 Średnio
Transceiver wg. M0NKA
GREG Offline
Liczba postów: 316
Post: #245
RE: Transceiver wg. M0NKA
(06-10-2014 10:35)SP3OSJ napisał(a):  Nowe firmware 189 sie pojawilo.
Plik z nowa wersja 0.189 jest tutaj:
.zip  mchf_firm_0_189_ka7oei_20141005.zip (Rozmiar: 70.61 KB / Pobrań: 955)
Zanim wgrasz soft wszystkie parametry ustaw na 0. Ja wgralem soft wczesniej niż informacja pojawiła się na forum YH (Zastanawiam sie jakie będą tego konsekwencje Smile).
Important note about saved settings:
BEFORE installing this firmware write down your TX and RX IQ gain and phase adjustments, your STG
(Sidetone Gain), WPM, RFG and other settings.
To work around a "bug" in the virtual EEPROM, the addresses had to be shifted so previous settings will
be disturbed!
YOU HAVE BEEN WARNED!
W moim wypadku przyspieszył Scope (UI 0.1).
Zmiany:
Changes in brief:
- Frequency, Mode and Filter now saved on a per-band basis.
- Start-of-band frequencies and sizes have been adjusted to align with Regions 1 and 2.
- The TUNE mode now works for USB/LSB without needing external audio tone generator for TX IQ Phase
adjust
- Keyer mode is now saved.
- Frequency can now be calibrated.
- Tuning range extended down to 1.8 MHz and up to 32 MHz
- Tuning scope screen update function more efficient: This should slightly help those with SPI-mode displays
(e.g. HY28A and/or Version 0.1 boards)
- Tuning scope smoothing filter will be less aggressive when in SPI mode: This should slightly help those with
SPI-mode displays.
- PA Bias is now properly loaded on power-up and calculated differently, with wider adjustment range.
- Delay on power-down (with countdown) to assure more reliable write to EEPROM when saving settings.
- Sub-display is now properly updated when RIT is set to zero.
(Ten post był ostatnio modyfikowany: 06-10-2014 12:47 przez GREG.)
06-10-2014 12:47
RE: Transceiver wg. M0NKA - GREG - 06-10-2014 12:47
