RE: Analizator EU1KY - SP9VEY - 24-07-2017 2:03
Po kalibracji moja antena KF wygląda tak
[attachment=13040]
Co jest mierzone na tej fotce?
[attachment=13041]
RE: Analizator EU1KY - SP7CLB - 24-07-2017 5:59
Chyba 10lg/s11/=10lg(/Zant/-50) - 10lg(/Zant/+50);
a zależność SWR od modułu /s11/ to: SWR=(1+/s11/) : (1-/s11/)
RE: Analizator EU1KY - SP9VEY - 24-07-2017 21:50
Jeszcze raz dziękuje za pomoc w uruchomieniu analizatora. Teraz zostanie zapakowanie go do jakiejś obudowy.
RE: Analizator EU1KY - EI8DRB - 04-08-2017 14:37
Hi all...
A am building teh v3 AA from Yury, but I am having a strange problem. If I try to do Hardware Calib. I get a meddage saying "No Signal". Also I get this message on the Measurement and Generator screen.
If I look at the input to the SA612 at OSCI, I see a square wave about 140mV P-P, but if I look at the output at OUTA or OUTB, I see noise.
Would anyone have any ideas?
Thanks
Gerry
Images here: https://goo.gl/photos/F4p8dSSjkF3YJiXv8
They are CLK1 output, OSCI input, OUTA output and screens from the AA
Output at CLK1
Input to SA612
Output from SA612
DSP Screen on AA
Gnerator Screen
RE: Analizator EU1KY - SQ8MVY - 04-08-2017 19:35
Hi EI8DRB,
Please show in high resolution PCB image.
Show also clk0 output, IN_A ( pin 1) in DA1 and IN_B ( pin2 ) in DA2.
HW_CAL jumper is closed and WORK jumper is open for Hardware Calib.?
RE: Analizator EU1KY - CANISLUPUS - 10-08-2017 9:20
Działa Wam dobrze TDR? U mnie pomimo zaterminowania kabla właściwą rezystancją nadal pokazuje jakieś odbicia.
RE: Analizator EU1KY - EI8DRB - 10-08-2017 9:49
(04-08-2017 19:35)SQ8MVY napisał(a):  Hi EI8DRB,
Hi Paul...
Thanks for offering your help.
Image links don't seem to work, so you can see all the images here:
The images you requested are the last 6, in this order: PCB, CLK0 out, DA1 in, CLK1 out, DA2 in., CLK1 taken at 510R.
I have the HW_CAL jumper closed and WORK jumper open.
Thanks
Gerry
The images you requested:
PCB
CLK0 output
CLK1 output
Input to DA1
Input to DA2
RE: Analizator EU1KY - SQ7BCN - 04-10-2017 8:08
Nowy Firmware do analizatora wer 3.17 na stronie autora.
RE: Analizator EU1KY - SP9VEY - 18-10-2017 8:14
(04-10-2017 8:08)SQ7BCN napisał(a):  Nowy Firmware do analizatora wer 3.17 na stronie autora.
Co nowego lub lepszego w nowym oprogramowaniu?
Sprawdził ktoś?
RE: Analizator EU1KY - SP1NV - 22-10-2017 23:51
Witam mam pytanie chciałem wgrać nowy soft po przez usb ale jak podepnę moduł to mi wykrywa 12kb i nowy soft nie mieści się . Nie wiem co robię źle
