Synteza SI5351 wg UT5QBC - Wersja do druku +- HomeMade (http://sp-hm.pl) +-- Dział: Urządzenia nadawczo odbiorcze KF (/forum-62.html) +--- Dział: Syntezy częstotliwości i moduły DSP (/forum-74.html) +--- Wątek: Synteza SI5351 wg UT5QBC (/thread-2823.html) |
RE: Synteza SI5351 wg UT5QBC - UT5QBC - 17-02-2019 19:14 SP5OXJ I went to the site and saw your message, your letter got into spam (((. Try to increase the capacity after a 3.3 V stabilizer and apply voltage to the input. Vin = supply voltage 12V RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 17-02-2019 22:21 Zbyszek, to synteza MICROB4 bez żadnych dodatkowych "Bajerów" z procesorem stm32f100cbt6b. Yuriy thank you for your answer. Your suggestions didn't help, but the synthesis works with old software "synthesizer__microb_v4_10102017.bin. Both newer versions from 2018 don't want to work. 73! de Jacek. RE: Synteza SI5351 wg UT5QBC - UT5QBC - 18-02-2019 7:27 Did you upload firmware for F100? Because there is a firmware for F103. The latest firmware for 2018 is all working, it has been tested many times. I recommend using it. synthesizer_stm32f100cbt6b_microb_v4_27122018.bin Make sure you have a controller with 128kB flash on board. I want to warn. Not all that is written is true. Here I have such a copy. It is written F100 and in fact it is F103. Thanks to the Chinese brothers! RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 18-02-2019 10:21 Yuriy, you are probably right. I guess I've some "painters" - only which ones? Works soft for f100cbt6b (only ver. from 2017) and f100c8t6b. others don't work at all or don't save menu changes. I'll leave the 2017 soft because the PCB may not withstand the next CPU change. Thank you for your help, 73! de Jacek. RE: Synteza SI5351 wg UT5QBC - UT5QBC - 18-02-2019 14:08 There is a suspicion that you have a 64kb flash controller. Read on the body of the microcontroller what is written, each char is important, and write to me. RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 18-02-2019 21:42 32F100 CBT6B GH2OX 93. CHN311 e2(in circle) Z RE: Synteza SI5351 wg UT5QBC - UT5QBC - 19-02-2019 7:58 128 kb microcontroller. exactly what is needed. Questions. What voltage do you apply? Pin Vin input must be connected to the positive voltage that is supplied to the synthesizer. In the system menu, the option "Low Voltage" is values set? What is the capacitance of the capacitor after the stabilizer 3.3v microfarad? https://drive.google.com/open?id=1r9esJ1tCHZOjy69uZedVz2v7Qel_qoaR try this firmware for today's date synthesizer_stm32f100cbt6b_microb_v4_19022019.bin RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 20-02-2019 8:05 " Pin Vin input must be connected to the positive voltage that is supplied to the synthesizer." I've missed this information before. Now it's working properly. It's good that processors are not expensive ;-) Thank you very much Yuriy. Vy 73! de Jacek. RE: Synteza SI5351 wg UT5QBC - UT5QBC - 01-03-2019 18:27 Firmware fix bugs HF Easy 2018. https://ut5qbc.blogspot.com/2019/03/firmware-fix-bugs-hf-easy-2018.html RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 22-03-2019 20:34 Yuriy, Is it possible to add 60m band to the Microb4 menu? Regards Jacek. |
