Synteza SI5351 wg UT5QBC - Wersja do druku +- HomeMade (http://sp-hm.pl) +-- Dział: Urządzenia nadawczo odbiorcze KF (/forum-62.html) +--- Dział: Syntezy częstotliwości i moduły DSP (/forum-74.html) +--- Wątek: Synteza SI5351 wg UT5QBC (/thread-2823.html) |
RE: Synteza SI5351 wg UT5QBC - UT5QBC - 27-12-2018 15:32 The problem is that I do not have these devices in my hands. If I add to the menu, there is no way to check how it will work. On hand there are only the latest models of "Easy 2017" and "Easy 2018". Changing the address itself is not a problem, it is the default entry. Guys, I want to say that I do not trade in printed circuit boards. So do not write me a personal message with the question of PCB. RE: Synteza SI5351 wg UT5QBC - SO6R - 27-12-2018 17:18 Yuriy, If you re-introduce i2c address selection in the "synthesizer_stm32f100cbt6b_microb_v4_10102017.bin release 10.10.2017" i would be more than happy to check it and confirm whenever it works ok. Darek, SO6R PS Jeśli ktoś potrzebuje plytki do Microb v.4 to zostało mi 5 sztuk z AllPCB,,,info via PW. RE: Synteza SI5351 wg UT5QBC - UT5QBC - 27-12-2018 17:45 Darek, Check and write about the result. https://drive.google.com/file/d/1zncRMvs5VojIfep7HuB8hEKZZgDqrWbB/view?usp=sharing I do not understand where you got the 2017 version. It has long been gone. RE: Synteza SI5351 wg UT5QBC - SO6R - 27-12-2018 19:51 Yuriy, Your latest firmware of Microb v4 have just been tested in on one of my devices with other than 0x60 address and it appears it is working fine....i verified the signal on osciloscope. Also nice to see that you limited i2c address range to just 16 to pick up. I checked my folder with all your firmwares and it appears I had the version dated 15.07.2018 loaded into the device with si5351 @0x60. Now full flexibility....quadrapure signal possible on all of my 3 sythesiers! Also I do like presentation of all data displayed in such a small display. Darek, SO6R RE: Synteza SI5351 wg UT5QBC - UT5QBC - 27-12-2018 20:14 Thank you Darek. RE: Synteza SI5351 wg UT5QBC - SO6R - 28-12-2018 16:48 Nadmiarowych płytek już nie mam. Szczęśliwego Nowego Roku Darek, SO6R (27-12-2018 17:18)SO6R napisał(a): Yuriy, RE: Synteza SI5351 wg UT5QBC - UT5QBC - 31-12-2018 13:01 Chłopaki, wszyscy z nadchodzącym 2019 !!! RE: Synteza SI5351 wg UT5QBC - SP7EZG - 01-02-2019 12:17 @UT5QBC Przepraszam, że odkopuję temat, ale muszę podziękować autorowi. Sam od kilku miesięcy miałem problem z użyciem Si5351 wraz z NE602. Mieszacz wprowadzał trzaski i inne niepożądane rzeczy. Okazało się - zgodnie z sugestiami kolegów, że sygnał wyjściowy z Si5351 jest zbyt wysoki, zatem trzeba go stłumić. Użyłem wczoraj rozwiązania zaproponowanego przez autora - proste rezystory 50R na wyjściach Si5351. Sygnał spadł, nie ma trzasków ani brumu. Widmo sygnału zadowalające, przy połączeniu bezpośrednim z RTL-SDR druga harmoniczna na poziomie tła. Oczywiście to co robię nie ma nic wspólnego z tym projektem, jednak pozwoliłem sobie zaczerpnąć tę ideę. Dziękuję! RE: Synteza SI5351 wg UT5QBC - SP5OXJ - 16-02-2019 23:49 Złożyłem tą syntezę i generalnie działa, tylko nie zapisuje ustawień w menu. Po każdym wyłączeniu wraca do ustawień "fabrycznych". Myślałem, że to wina procesora, jednak po wymianie jest tak samo. Pisałem do autora, ale nie dostałem żadnej odpowiedzi. Może ktoś z Kolegów ma jakiś pomysł? 73! de Jacek. RE: Synteza SI5351 wg UT5QBC - SP6LTP - 17-02-2019 13:43 (16-02-2019 23:49)SP5OXJ napisał(a): Złożyłem tą syntezę i generalnie działa, tylko nie zapisuje ustawień w menu. Którą wersję zbudowałeś? Aby odblokować pełną funkcjonalność syntezy należy uzyskać od autora kod odblokowujący. Dane są na stronie autora. |
