RE: Transceiver wg. M0NKA - SP3OSJ - 24-09-2014 19:48 ..... RE: Transceiver wg. M0NKA - GREG - 28-09-2014 13:05 Artur, Strasznie drogo. Pojawiła się wersja 187, która rozwiązuje kilka problemów. - The bug in which there was a disruption when the STEP+ and/or STEP- button was pressed is now fixed. There is no need to remove the capacitor(s). (Please put them back to protect against RFI/static if you removed them!) - A minor bug in the volume control in which two of the volume settings were the same is fixed. - Problems with the audio un-muting in CW mode after TX have been fixed (mostly.) - RX Phase adjustment has been added. - TX Phase adjustment has been added - but it has effect ONLY in SSB mode! - The TX/RX calibration settings now actively change with TX/RX mode, and the TX Phase adjustment is only possible in USB or LSB mode where it has an effect! - The CW TX and RX frequencies are now aligned with each other, and they fall within the center of the 300Hz and 500 Hz wide CW filters. (Sidetone/offset is 750 Hz - fixed, at the moment.) - The problem with very poor opposite sideband rejection on TX has now been fixed! Więcej szczegółów: https://uk.groups.yahoo.com/neo/groups/M0NKA-mcHF/conversations/messages/250 Pozdrawiam RE: Transceiver wg. M0NKA - SP6AUO - 28-09-2014 20:53 I w dalszym ciągu nie ma co testować.Poziom szumu bez anteny na s7. Ten program ma od początku źle ustawione wzmocnienie. Czy Ktoś ma inaczej.Proszę napisać zdanie. RE: Transceiver wg. M0NKA - SP3OSJ - 28-09-2014 22:46 ..... RE: Transceiver wg. M0NKA - GREG - 29-09-2014 13:47 (28-09-2014 20:53)SP6AUO napisał(a): Poziom szumu bez anteny na s7. U mnie to samo. Od 18MHz w górę pisk. Zastanawiam sie, czy soft nie jest pisany pod inne wersję UI (moja 0.1) a wersja RF 0.2. Wersja UI ma delikatne różnice i może stąd te nasze problemy. Ja np. nie mialem problem ze "strzałami" przy zmianie STEP -/+ Podrawiam RE: Transceiver wg. M0NKA - SP6AUO - 29-09-2014 15:15 Ja do tej pory dokonałem takich zmian. 1: wyrzuciłem Q1 i jego otoczenie, 2: wymieniłem R3= 1k na 47k, 3; wymieniłem C7=C8=470n na 10n, 4; używam soft 181, 4; filtry na 80m i 40m ustawione. Odbiór i nadawanie poprawne.Na temat pozostałych pasm nie wypowiadam się, brak anten. Teraz zabrałem się za porównanie programów 181 i 185.Chcę ustalić co się stało z nastawą m.cz. Bo te inne zmiany mogą być dobre.Tylko z szumem na S7 nie da się ocenić właściwie nic. Pozdrawiam. RE: Transceiver wg. M0NKA - GREG - 29-09-2014 22:41 Witam ponownie, Pojawiła się lista modyfikacji. [attachment=9033] Proszę o informacje, czy któryś z Kolegów wykonał te modyfikacje i jak się sprawdzają w praktyce? Pozdrawiam G RE: Transceiver wg. M0NKA - SP3OSJ - 30-09-2014 0:17 ..... RE: Transceiver wg. M0NKA - SP6AUO - 30-09-2014 2:10 Ach zapomniałem. Dołożyłem 3,3 oma 0805 w torze zasilania LM386, tak mniej więcej w miejscu jak w opisie. RE: Transceiver wg. M0NKA - DM9IAH - 30-09-2014 11:43 Dzień dobry wszystkim Kolegom na forum. Na wstępie chciałbym podziękować koledze Andrzejowi za pomoc w programowaniu Boota i Softu. Lcd świeci i wyświetla co powinno. Mam pytanie do Kolegów bo nie jestem pewny czy jest to normalny objaw czy nie. A wiec do rzeczy: Zmontowany procesor + lcd nic poza tym. - W momencie kiedy przekręcam gałkę strojenia o jeden w prawo albo w lewo nie reaguje,dopiero jak przekręcę o kilka kliknięć enkodera to pokazuje przejście częstotliwości o ustalony krok. - te trzy enkodery po lewej stronie tak samo. - przyciski muszę przytrzymać ponad dwie sekundy ażeby zaskoczył o co mi chodzi. Z początku myślałem ze nie ma si570 i procesor czeka na odpowiedz zwrotna o dojściu do zadanej częstotliwości ,ale co z reszta. Proszę odpiszcie czy mam szukać jakiegoś błędu czy jest to normalne do puki nie będzie reszty elementów peryferyjnych. pozdrawiam Mirek. |
